1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Royal Sport Bed
Old 06-11-2011, 02:19 AM
Superduty_7.3's Avatar
Superduty_7.3
Superduty_7.3 is offline
Royal Sport Bed
I currently have a 2001 F350 with 7.3 diesel and it has the 9ft. Royal sport bed on it. I am looking to get a standard 8ft. bed has anyone ever switched one of these out or have a available 8ft. bed.
Old 06-11-2011, 02:23 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I'm sure a factory bed will bolt right up. I cant imagine Royal making their bed so extensive as to modify the frame.
Old 06-11-2011, 02:31 AM
Superduty_7.3
Where is the easiest place to get a bed and do multiple year beds bolt up
Old 06-11-2011, 02:37 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Any 99-11 will bolt up but they changed the looks of the bed for 2011. The best place to find beds it truck upfitters and body shops.
Old 06-11-2011, 04:43 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
On your door sticker does it say "incomplete vehicle" that may create an issue.
Old 06-11-2011, 08:35 AM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
That would depend on if it started life as a pickup, or chassis/cab.
Old 06-11-2011, 10:12 AM
jc8825's Avatar
jc8825
jc8825 is offline
Even if it was built initially as a chassis cab, worst case scenario, wouldn't the holes for the bed mounts just have to be drilled into the frame or is the frame different?
Those Royal Sport beds are ugly IMO.
Old 06-11-2011, 10:21 AM
Superduty_7.3
It was my dads truck and he used it for work purposes and I inherited it when he passed away now I want a standard bed truck did say incomplete but like some of u said should not be a big deal
Old 06-11-2011, 10:24 AM
jc8825's Avatar
jc8825
jc8825 is offline
I would just look at the mounting blots on your bed and compare to another LWB SD. If they are in the same places, the bed will swap right out, AND if the Royal Sport bed is in good condition, you could sell it and recoup some of the cost.
Old 06-11-2011, 12:20 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
maybe this guy would swap : looking for utility bed (oem looking, royal sport) ..anyone have one? - Ford Powerstroke Diesel Forum
I'd contact royal sport and ask if they use the stock holes. If So, I'd place ads everywhere, (this forum, CL, etc) and see if anyone wants to swap.
Old 06-11-2011, 11:48 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
cab/chassis trucks have different rear frames then pickup models.. so the bed from a reg truck wont simply bolt up..
Old 06-15-2011, 08:43 AM
AnneCraw4d's Avatar
AnneCraw4d
AnneCraw4d is offline
I'm looking for a 9' Sport body if anyone has a lead on one. And you can contact Royal directly to ask about swapping out the body. I know the Sport Body was mounted onto a cab chassis directly. Their website has contact info: Royal Truck Body
Old 06-15-2011, 10:10 AM
LSchicago2's Avatar
LSchicago2
Chassis cabs are narrower, @ 34" wide, and don't have the dip that pickup frames do. Lot's of work to make a bed designed for one fit the other.
Old 06-15-2011, 11:18 AM
Wagion's Avatar
Wagion
Wagion is offline
https://www.fleet.ford.com/truckbbas...superduty.html
Try this link it is the 2001 Body Builders Guide it has all the frame measurements in it and all the holes along with sizes
Old 06-15-2011, 11:23 AM
Wagion's Avatar
Wagion
Wagion is offline
Can you post some pictures of the bed? I had never seen that before started looking online the is exactly what I want If I lived near you and the bed was in good shape I would swap with you.
There is so much wasted space between the inside bed sheet metal and the outside sheet metal on these trucks. Dodge has a good idea with the new storage lockers on the side of the beds.
Quick Reply: Royal Sport Bed
