4spd bellhousing
Old 06-09-2011, 10:06 PM
salf100's Avatar
salf100
salf100 is offline
4spd bellhousing
Looking for the part number if any and anyone selling a bellhousing that came on the 51-53 trucks that had a flathead motor and four speed trans. Thanks
Old 06-10-2011, 07:34 AM
kenjh's Avatar
kenjh
kenjh is offline
I cant see through the grease an grime on mine ..but Ican check the spare motor over the weekend and let you know..
Old 06-10-2011, 07:39 AM
Granny1153's Avatar
Granny1153
Granny1153 is offline
1953 had a different bellhousing, one of a kind and only 1 year except canada. Similar to the 6 cyl and y- block motors except the mounting bolts were narrower. The part # that i came up with in my search is taac-7505-A. I am looking for a 53 ford flat head bell housing.
Old 06-10-2011, 08:27 AM
salf100's Avatar
salf100
salf100 is offline
Ok, what's the model name of the both transmissions, 51-52 & 53. I'm tring to get the info for a buddy that's doing a custom set up with an S-10 T-5
Old 06-10-2011, 12:37 PM
old_dan's Avatar
old_dan
old_dan is offline
I'm pretty sure Ilya has one (aka 51panelman).
Dan
Old 06-10-2011, 04:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I would guess what he's after is a "hogshead", you should ask him to be sure. The bigger truck trannies had a separate piece behind the bellhousing that the trans attached to. Those are popular to adapt an S-10 trans. See below:
T5 Transmisison Swap
https://www.ford-trucks.com/forums/4...sing-help.html
KK560
Engine Swaps
02-25-2017 02:47 PM
Fordworth
WTB - Parts & other
03-09-2010 11:49 AM
pcmenten
20
08-08-2007 06:08 PM
1982fordf100
02-02-2004 05:55 PM
Andy W
10-31-2002 01:27 AM
Quick Reply: 4spd bellhousing
