got a code 452
got a code 452
Just got done installing a water pump and my code scanner just showed up. So I pulled a code from continuous memory 452 vss signal fault. I'm sure this would contribute to my hard/erratic shift problem. My question is where do I start? Already changed the vss on the diff. What's next wire, tone ring, bearings?
You have already replaced the VSS, the next step would be to ohm out the wiring. I had some wires chewed up my some pesky squirrels on my last '93 Lightning. Amazing what those critters can do!
I have read somewhere you can use a DVM set to AC to measure the signal output. Jack up the truck, block the wheels, place the DVM on the VSS output, run the truck in Drive up to 30-35 MPH. The meter should read in the 3.0 - 3.5 volt range. If it does not then you may have a bigger issue such as a carrier bearing problem or broken teeth off the tone ring inside the rear differential.
Several here have found the RABS valve is dragging down the VSS signal, you could try disconnecting it as a test too.
Torky2
1978 - 1996 Big Bronco
22
05-22-2016 08:52 AM
Quik
05-20-2015 08:54 PM
Playing_Tough
09-26-2006 08:19 AM
