got a code 452
Old Jun 8, 2011 | 01:41 PM
tony. b's Avatar
tony. b
got a code 452
Just got done installing a water pump and my code scanner just showed up. So I pulled a code from continuous memory 452 vss signal fault. I'm sure this would contribute to my hard/erratic shift problem. My question is where do I start? Already changed the vss on the diff. What's next wire, tone ring, bearings?
Old Jun 8, 2011 | 11:01 PM
rla2005's Avatar
rla2005
I will ask this: Did you clear the codes after you replaced the VSS?
Old Jun 9, 2011 | 05:48 AM
tony. b's Avatar
tony. b
Yes I have disconnected the battery several times. If I disconnect the battery the hard shifting will go away for alittle bit then ill drive it for a bit and it comes back along with not shifting at the right times.
Old Jun 9, 2011 | 07:07 AM
rla2005's Avatar
rla2005
You have already replaced the VSS, the next step would be to ohm out the wiring. I had some wires chewed up my some pesky squirrels on my last '93 Lightning. Amazing what those critters can do!
I have read somewhere you can use a DVM set to AC to measure the signal output. Jack up the truck, block the wheels, place the DVM on the VSS output, run the truck in Drive up to 30-35 MPH. The meter should read in the 3.0 - 3.5 volt range. If it does not then you may have a bigger issue such as a carrier bearing problem or broken teeth off the tone ring inside the rear differential.
Several here have found the RABS valve is dragging down the VSS signal, you could try disconnecting it as a test too.
Torky2
1978 - 1996 Big Bronco
31
Dec 19, 2024 09:01 PM
86F150302
15
Sep 13, 2016 06:47 AM
chesster51
May 22, 2016 05:04 PM
Quik
May 20, 2015 08:54 PM
Playing_Tough
Sep 26, 2006 08:19 AM
