Opinions please ATS trans kit
I'm looking into beefing up my trans this winter with out breaking the bank has anyone ever used this kit or know anyone that has. I want something that will hold 350ish hp
Ford Transmission Upgrade Packages - ATS Diesel
on
I would go with Racer X for Parts. Actually I DID! Give them a call. They have many more parts availible than what is on the website. They can also give advise if needed.
RACER X USA
BTS doesn't offer parts. Only complete transmission.
RACER X USA
I found this kit is this a good deal
http://www.redrider.us/e4od_performa...missions_a.htm
#KE4OD. Build your own Level 4 Enforcer transmission. Fits all E4OD transmissions, 1989 on. You get all Red Eagle clutches and Kolene steels plus 4 Alto Power Packs. Red Eagle Power Packs and Kolene steels for 1st, 2nd, 3rd and overdrive. You also get a Transgo Shift Kit, power valve, overdrive spiral snap ring, 45 element sprag, triple clutch torque converter (#3D4/6 or #3G4/6) and our 300M input shaft. This price includes the overhaul kit, carbon fiber band and filter. Add molded pistons, bearings, thrust washers, solenoid pack, pump and pressure valve if needed. You save $160.00 or 10%. All of this for $1441.00.
