Slight chugging on acceleration
Hey Mr... By popping I'm reading your suggesting like a popping back through the, as an oldtimer I would say carb but through the throttle body. If so I would suggest might be a valve maybe hanging up which a compression test would prove. Specially as you've change everything else.
Mine is a slight hesitation with a loss of power every now and again with no popping or anything. Happens at low around 30 mph and a simple kick on the throttle gets it going again.
The test which needs to be run is the Cylinder Contribution Test. A shop which has a Snap On scanner with the latest software will be able to run the test and see if any particular cylinder is performing below the others. The data is live and can be graphed to capture the information on a test drive and saved for review.
But I'll check the compression after I fix my o\d flashing.
I got the truck from ford service, for hours and they said every thing is in perfect condition , and they did a transmission wiring harnesses fix , but flashing and slamming 1,2 gears appears after a short drive .
hail destroyer
10-02-2016 06:32 PM
1995BFF
09-27-2016 01:13 PM
