95 F250 351 No power, trouble pulling trailer
I have a 1995 F250 with a 351. It has 154,000 miles.
I just replaced the heads with reman units from Napa. Also, the cap and rotor, spark plugs and spark plug wires. I put Hooker long tubes, an H pipe and 2 chamber flowmasters on it. It has factory 3.55 gears and 285/75/16 Dynapro tires (brand new tires).
Before I did all this, when you hit the gas it would hesitate at any speed. If you were going 40-60mph it would just stumble and sputter and accelerate slowly if at all.
Now with the repairs that problem is mostly gone. Going 40-60mph if you hit the gas, it moves but you can still feel a slight studder. It feels like its popping inside the engine. It will accelerate now, but not very fast.
Also, I pull a lawn trailer and tractor (about 1600lbs total). With the overdrive off, it will lose speed going up hills. It's a challenge just to maintain 55mph.
After about an hr of driving with a trailer, the trans from a stop will shift quickly through the gears and not take off fast. What is going on there?
I know these trucks are not powerhouses! But I feel like it should run better and pull harder after these repairs/mods. I want to pull a 27 foot camper with this truck next summer, and right now I know it wouldn't make it.
Any advice on other areas to check for problems?? Throw some 3.73 gears in it?? THANK YOU! _Jamison
lippsenator
34
04-19-2018 12:28 PM
seefour
06-06-2004 10:01 PM
Dustin R
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-14-2003 03:30 PM
