A different kind of Spark Plug Problem......
More of the same, just different, and perplexing.
I bought a 1998 Expedition 4X4, 3rd row seats, power everything in great shape for $800. It has the 5.4 and Auto Trans (not sure which one). I got such a great price because #3 sparkplug had blown out. I checked the internet, called NAPA and called Ford and found out this really isn't that big of a deal and it is an easy fix.
I pulled the harness for the injector, fired her up and drove her home. Sounded like an old Johnny Popper John Deer. I went to NAPA and got the insert kit I needed and the hole was bigger then the tool. My brother has one of those cameras that reach into places like spark plug holes and we could insert the head (11/16 inch diameter) all the way to the piston.
So, I called the previous owner and he told me that he had repaired that spark plug hole once before, but he could not remember what kit he used.
Common sense says I am going to have to replace this head. I'm hoping that one of y'all has used a kit that needs a hole almost 3/4 of an inch in diameter......
The head is cheap ($60) at a local junk yard, the labor is not ($1200 plus a gasket set) at the local Ford dealership.
Any ideas?
Thanks in advance.
Steve
Any ideas?
Thanks in advance.
Steve
++ TIME-SERT FORD SPARK PLUG REPAIR, blown out spark plugs problems blowout Frequently Asked Questions ++
Call this place, they will hook you up.
This is the most popular and best kit out there!
Timesert may have oversized inserts available. Give them a call.
Heres another brand thats similar to the timeserts.
http://fulltorque.com/sparkplug.htm
If neither of them have anything you could always contact these guys. http://www.blownoutsparkplug.com/
Full-Torque Spark Plug Inserts
If neither of them have anything you could always contact these guys. Blownoutsparkplug.com Ford Spark Plug Thread Repair
Try this kit It is by far the best insert kit I have used and the tap is 3/4" so it may work in your head. I have installed prob 20 inserts and none have came out.
I'm going to have to change the head.
porky1980
12-29-2015 04:43 PM
JaySVX
09-01-2015 05:06 AM
