94 f150 stuck in four wheel drive,pls help
Old 06-03-2011, 11:50 AM
shane1963's Avatar
shane1963
shane1963 is offline
hi,i just bought a 1994 f150 4x4, 4.9 litre inline 6, 5 spd,engine,manual hubs,problem is when i driving down the road in 2wd,it sounds and feels like its still in 4wd.iv made sure hubs are unlocked,the feel and sound seems more noisy in 3rd and 4th gear.would backing up help like the old trucks.thnx for any help,shane.
Old 06-03-2011, 11:59 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Is it push button 4x4 or manual on the floor?
Old 06-03-2011, 12:39 PM
shane1963's Avatar
shane1963
it is the manual on floor type,also the 4x4 low high etc lights are all working.
Old 06-03-2011, 01:48 PM
andym's Avatar
andym
andym is offline
If it's in 2hi and the hubs are unlocked, then you should able to spin the front driveshaft. Watch the front axles and if you have a frozen hub you'll see it.
Also, I've never been able to feel or hear whether the truck is in 4wd. It should be quiet and smooth. You may have a frozen or stuck front u-joint.
Old 06-03-2011, 02:42 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
have you checked the fluid in the Tcase yet? I have also heard that transmission can be a tad noisy in 3rd/4th gears.
Old 06-03-2011, 06:55 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
mine started stickin in 4x high when my 13-45 t-case started goin up. in the early stages, i could get it out of 4x by rockin the truck back n forth while puttin pressure on the t-case shifter. . .later on nothin would get it into 2x except outright beastin on the handle. thats when i replaced it.
i can tell mine is in 4x4 or my hubs are locked once im at highway speed (50+). when i forget to unlock my hubs she lets me know. with your hubs unlocked (assuming you can tell and be sure they in fact are unlocked) the driveshaft will be moving when its in gear and rolling if youre in 4x.
Old 06-03-2011, 08:10 PM
shane1963's Avatar
shane1963
only had the truck couple days now but went out on highway and put hubs in 4 high,turns out my new truck is just real noisy in 2wd,4wd works ok,but seems to want to pull to the right when i floor it and its a lot noisier then when in 2wd,(mega hum} kinda reminds me of a skidder or loader trannie. i will change my oils in trnsfr case and rear and front end.hopefully that will make a difference,the oil in front looks greyish black as does the rear.thnx for all your help.
Shane Jenkins
03-03-2017 10:09 AM
Mustangoutcast
1978 - 1996 Big Bronco
01-19-2017 06:43 PM
shanes66charger
81
05-25-2016 02:49 PM
shanes66charger
04-21-2016 02:21 PM
Shane in WI
51
07-26-2009 06:53 PM
Quick Reply: 94 f150 stuck in four wheel drive,pls help
