04 expedition 4.6 2 wheel drive vibration, grinding on acceleration
I have an 04 expedition that has a grinding noise, and vibration that only happens around 1300-1800 RPM, when the truck is in gear, any gear any speed. I hear the noise off idle under partial throttle, and feel the vibration in the accelerator. It is most prevalent at low speeds, worst when leaving from a stop, but also occurs at highway speeds. Any input would be greatly appreciated. Just want to get some general ideas before i tear into the truck searching blindly.
Just installed new plugs and coils about a month ago, had a intermittent miss and rough idle, those are gone, but the vibration and hesitation on down shift remain... A buddy suggested it could be vacuum related... But I have checked to the best of my abilities and have not found any leaks... I'll check the u joints in the morning.
Did a quick check of the u joints... There is no movement, or play when trying to turn the driveshaft by hand and holding the yoke with the other hand... Was told this was a quick way to check if there was an issue... Do they maybe just need to be greased? Last oil change I was busy and didn't have time to do it myself...must admit I went to jiffy lube... Maybe they didn't grease them like they claimed they would... Idk thanks for the help so far guys any additional input would be greatly appreciated.
All that checks is that neither one has broken and the driveshaft hasn't fallen out of the truck. I think you have one or more bad u-joints. There is no way to check that with the driveshaft installed in the truck.
jjoel
06-11-2010 06:24 PM
bigputzars1
1997-2006 Expedition & Navigator
09-09-2004 01:08 PM
