Transfer case Boot
The following users liked this post:
I think the only manual transmission offered in the 87 F150 was the BW T18 4 speed.
The T18 was discontinued some time around 1990.
The Mazda 5 speed was introduced in 1988.
The shape of the transmission tunnels are different. The 4 speed tunnel was wider and flatter
on top so the boot for the transfer case mounted to a flat surface.
The is a picture of the transfer case shifter boot used if you had a Mazda trans.
years 88-96. It doesn't show the angle when it's mounted but it mounts to the side of
the transmission tunnel. So if you have the 4 speed trans. the boot below won't work.
Disregard what I said in my first post. I just wanted to provide one
reason why the transfer case shifter boot for the 88-96 would not fit
your 87.
Here's a picture of the transfer case shifter boot for a 87 Bronco
(F150 should be the same). It mounts flat on the transmission hump
and not on the side of the tunnel.
This picture shows the side mounted boot.
your 87.
I know this is a very old thread. Buy I have searched and can't find that boot either. Have you had any luck? Thanks
I saw this is a 10 year old post but apparently this is incorrect information. Apparently it was available until ‘93.
https://www.ford-trucks.com/forums/1...-cylinder.html
what is your vehicle, auto/manual?
look at #9--> Floor Shift Components
Good luck in your search.
