Spout Connector question?
Decided to bump the timing up a tad, and I'm noticing everyone says unplug the SPOUT connector.
My question is: Do I unplug the SPOUT connector Before I turn the truck on, or while it's running? Also When it's unplugged and I bump the timing, do I plug it back in THEN turn the truck off? Or wait till it's off then plug it back in?
Thanks in advance!
Thanks in advance!
planehunter's method is what most people do. Some people will start the truck and unplug it only long enough to adjust the base timing, then immediately plug it back in with the truck running. Reason being is that unplugging it can trigger a trouble code and then the computer thinks something is wrong when it isn't.
Both ways are fine though.
I know, I know, i'm digging up an old thread. But it's better than starting a whole thread for a simple question. Here's the simple question.
I've tried to advance my timing two separate times now but both times I ran into a problem with the spout connector. If I start the truck and pull it while it's running the truck dies immediately. If I pull it and then start the truck the truck just cranks and cranks but won't start. Is the problem with me or with the truck?
The problem is with the truck.
Not saying you have a problem with your computer but others have fixed this problem by replacing the computer.
But first I would check your start wire from the TFI module (ICM) to the starter solenoid. Then I would replace the TFI module (ICM) and then if needed the computer.
Are there any other known issues when it's acting up like that, is it just that I can't adjust the timing or are there other problems?
tempest411
23
06-24-2017 11:39 AM
Prozon
13
01-11-2016 01:44 AM
bobrpm306
48
02-09-2013 10:18 PM
Nally427
08-06-2012 12:50 PM
MrRogers
06-09-2010 05:58 PM
