02 F250 V10 **TRUCK WENT CRAZY**
Ok so I have a 02 f250 v10 4x4, 85k miles. Truck has always ran great, I am driving down the my road yesterday, I came to the stop light and the truck cut off. I started it back up, started fine, but check gage light was on, trans temp guage not working, engine temp guage not working, tach not working, O/D light is blinking, check engine light on, passenger window would go down and not back up, so I turned around to head home, the truck was shifting a little erratic ( never had any problems ever with trans ), the truck seemed to be misfiring some, the only guages that seemed to be working were the speedo and fuel gauge. I got home, pulled out my scanner, plugged it in, waited it came up saying error. the scanner has always worked on the truck in the past. I checked all fuses and relays, everything is good. ANY IDEAS?? thanks for the help ahead of time, a couple of my local ford buddys are saying pcm is bad??
It sounds very similar to when my windshield was leaking and the fuse box/GEM module was getting wet. I had no window functions, the only guage that worked was the speedo, truck stopped charging, tranny acted up, OD light flashing, ect. I had to replace the fuse box under the dash and all was good. That and fix the windshield leak.
Steve S.
To many to list.
Steve S.
To many to list.
GreenMachinee
12-03-2014 04:57 PM
Devilmanak
18
04-07-2013 05:48 PM
