04' Explorer front wheel bearing replacement
Old 05-25-2011, 07:17 PM
Donny_D's Avatar
Donny_D
Donny_D is offline
Hey guys im an older member i had a 99; F-350 and was from that forum. The wife and I picked up an explorer and the front wheel bearing is shot. Does anyone have a Chiltons break-down on how to replace the driver side front wheel bearing. Some more info on the car, its 04' ford explorer, with the 4.0. 4 w/d, not the sport track. Thanks in advance to anyone that can help.
Old 05-25-2011, 08:52 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
the 4 wheel drives have a hub / bearing unit that you replace. You do not change just teh bearing. Basically you jack up the tire, remove tire/ rim, remove the axle nut in the center lf the hub and push the alxe inward 1 inch. Remove brake caliper and disc. Reach around the backside of the hub unit and remove the 3 bolts holding the hub to the knuckle. Then pull the hub unit off... Works same as all front wheel drive cars and 4 x 4 newer trucks ( last 10 years or so). Bearings are permanent sealed, can not be greased.. I will post a youtube movie if i can find one... Bearing/ hub is about $200 at Auto Zone.. you can get one off e-bay for about $80. MOST are made in china these days.
Old 05-25-2011, 08:56 PM
steve(ill)'s Avatar
steve(ill)
Old 05-26-2011, 10:56 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Good video, just like the one I repaired last month... Philip
Old 05-26-2011, 11:25 AM
dan8052's Avatar
dan8052
dan8052 is offline
One word of caution when replacing the hub/wheel bearings... you get what you pay for! I purchased 2 hubs from Advance Auto for my '96 Explorer and could tell the drivers side was bad before I made it past the neighbors driveway (50 ft.).
Old 05-26-2011, 06:13 PM
Donny_D's Avatar
Donny_D
Donny_D is offline
thank you all for the posts i really appreciate the help.
Old 05-27-2011, 01:54 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
We offer three different options on these.We carry generic, Motorcraft and also the Timkin bearings for this year Explorer.
Here's a link to them on the site.
2004 Explorer Bearing Hub Assembly
Jon Paulsen
02-20-2016 07:23 PM
powersmoked
10-20-2013 04:38 PM
Unrealo4
05-10-2011 07:32 PM
zzrich
04-11-2010 03:27 PM
osheam
04-20-2008 10:38 AM
Quick Reply: 04' Explorer front wheel bearing replacement
