Old 11-25-2014, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
Print Wikipost
Rear Differential Issue.
Old 05-25-2011, 06:55 PM
meierw1's Avatar
meierw1
meierw1 is offline
last week I broke the pinion and spider gears in in rear end. Well Im getting a used rear end rather than rebuidling mine. Does anyone know the gear ratio on the 97 F150 xlt 4.6l 4x4. I figured they would all be the same but my tag is missing on my diff and I was told by an auto parts store that there were a couple different ones. Thanks
Old 05-25-2011, 07:53 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
trust me, its ALOT cheaper and easier to rebuild the rear end. but, if you insist on buying used, its probably 3.55. but, look on the door jamb and post the axle code on here.
Old 05-25-2011, 08:25 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
Axle Codes
L - Limited Slip Differential
C - Conventional Differential
Code Ratio
18 3.08C
19 3.55C
24 3.54L
25 4.10C
26 3.73C
27 3.31C
28 3.73C
B5 4.10L
B6 3.73L
H9 3.55L
Old 05-25-2011, 08:51 PM
meierw1's Avatar
meierw1
meierw1 is offline
how much does it cost to rebuild the rear end? I have family that works at the ford dealership so I get a good price on parts. I was told it would be easier to swap rear ends.
Old 05-25-2011, 10:11 PM
93 mix 'n match
if its just the gears inside the differential (pinion/side gears) then its relatively cheap. i did mine, which is a limited slip differential so i replace the clutch packs for around $250.
it was 150 for the gears
around 6-70 for the clutch packs (only needed if you have a limited slip)
then of course, $22 for rear fluid and $5 for the RTV. all thats needed is basic tools and a torque wrench if you decide to take the carrier out.
i mean, im only 17, and its not like i go to school for this yet. and i did it in a weekend. its easier then it seems if you have a basic automotive knowledge.
Old 05-26-2011, 06:46 AM
meierw1's Avatar
meierw1
meierw1 is offline
Im 20 and know pretty much about workin on cars and trucks. My axle code is h9 which is limited slip. If its only 250 ill rebuild mine.
Old 05-26-2011, 08:39 AM
93 mix 'n match
Old 05-27-2011, 10:06 PM
meierw1's Avatar
meierw1
meierw1 is offline
does anyone know is all the axles listed above are interchangable ?
Old 05-28-2011, 08:22 AM
93 mix 'n match
theres only 2 different types of axles. whats listed above is the different gear ratios. if you're replacing the whole axle, then you'll either have a 8.8 or a 9.75. they cannot be interchanged without a different driveshaft.
Old 05-28-2011, 10:24 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
SwOkcOffRoader is offline
It takes a bit more than just removing and installing a ring and pinion. You have to set pinion crush properly, and the lash as well. If you don't know how to do it, research it up and down before you even drain the diff. If then you feel confident you can do it all properly, then by all means go for it, if not find someone who knows how to set a ring and pinion up properly. If it's not done right you can tear new gears up in a short time. One tip I can offer is upon teardown, keep close track of which sides the carrier shims come out of. It's not extremely difficult job to rebuild a diff, but it definitely has to be done exactly right. Swapping out the whole unit is a bit more "plug and play" as long as the axle you get is in good shape.
Old 05-28-2011, 08:31 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
As said above, best to research for this job. Here's a gear install from a 4x4 site that should give insight to the procedure of an install which may help your decision to do it yourself. http://www.pirate4x4.com/tech/billavista/Gear_Setup/
There's usually small shops, they don't have to be speed shops, that specialize in diff repairs that will be far cheaper than using a dealership for parts and labor. Try the Yellow Pages in your area.
Note. this is a dana 60 install, not a 8.8.
Old 05-28-2011, 09:02 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The 8.8 is a very easy axle to rebuild not as easy per say as maybe a removable carrier unit like a 9'' is but you should be able to handle the job. You will need a press to replace the bearings and a dial indicator to set the gears and shims. May want to buy an extra crush collar to as you only get one shot with them. Plan on 6 hours for a first timer.
Old 05-29-2011, 06:43 AM
93 mix 'n match
reading is fundamental. hes not replacing the ring and pinion, hes replacing the pinion gears and side gears, AKA spider gears. so no specialty tools or shops needed.
Old 05-29-2011, 08:30 AM
SwOkcOffRoader
I highly doubt he broke the pinion without messing up the ring gear. But either way, replacing the pinion requires the new crush sleeve to be set right, and the gear lash done with a micrometer. If JUST the spiders broke, then it would be a simple spider gear swap.
Old 05-29-2011, 09:52 AM
93 mix 'n match
ugh... HIS RING AND PINION ARE FINE!!!!! HE BROKE THE SPIDER GEARS. THE GEARS INSIDE THE DIFFERENTIAL ARE CALLED SPIDER AND PINION GEARS. HIS RING AND PINION ARE UNHARMED.
Quick Reply: Rear Differential Issue.
