460 to M-6007 M-50 5.0 Swap into a 1997 F-350 possible?
So the more I think about building my 460, the more I'm considering just doing a major swap, like the new 5.0. First of all, is it possible? (motor mounts, bell housing, etc) And if so, I'm thinking I could have almost the same torque, 2x the HP, and a MUCH more efficient engine that would probably get around 14 - 16mpg in my F-350. Would it be stupid? Or should I just spend the 6k that I would on a 5.0 crate on the 460 and have an insane 460. What I like about the 5.0 is it's just plain more efficient...4 valves per cylinder, heavier duty bottom end, piston cooling jets, etc... What are you guys' opinions? Pros and cons please
it's not an easy swap anyway shape or form. You will be changing EVERYTHING. and I mean EVERYTHING, including wiring (all of it) transmission, not only motor mounts but you probably will have otmodify the perches. And I thought I heard somewhere that even the radiator will have the wrong inlet outlet.
According to my last dyno i'm at 341 wtq and 210 whp. That's bone stock other than the AEM SEFI conversion.
First run:
second
Final fun. Think I could gain at least another 10/10 if I didn't have stock exhaust manifolds. picked up a lot of low end torque by adding about 4 degrees of timing down low.
First run:
second
Yeah after i converted it i tuned it myself....i wouldn't ever let anyone think about tuning my precious 460!
Yeah i'm thinking all the above plus roller everything should get me close to 400. The thing about the 460 is it's got the potential but it's just so choked down!! All I gotta do is get the torque to keep going instead of dropping off around 3k rpm and i think it'd make some serious power
pbs664
04-28-2015 02:05 PM
1992FordF150Custom
17
11-25-2012 12:47 AM
