Question on F-100/150 4wd engine towers/mounting vs F-250
Not having owned an F-100/150 4wd, but owning a 70 and 76 F-250 (260) 4wd CC's, does the two frames mount the engines the same way and use the same towers, or is there a difference between the F-100/150 and the F-250 towers?
Not having owned an F-100/150 4wd, but owning a 70 and 76 F-250 (360) 4wd CC's, does the two frames mount the engines the same way and use the same towers, or is there a difference between the F-100/150 and the F-250 towers?
Towers are related to 2WD's only, as they bolt to the crossmember that a 4WD does not have.
4WD engine supports bolt to the inside of the frame rails.
1965/67 F100/250 352 2WD / 1968/73 F100/350 360/390 2WD / 1974 F100/350 360/390 2WD before serial number U00,001.
2) D4TZ-6038-A .. Right & Left Front Rubber Insulators / Obsolete
Applications: 1974 F100/350 360/390 2WD from serial number U00,001 / 1975/76 F100/350 360/390 2WD.
