Radio, no volume
Also GDM there is what is called an antenna trimmer on the radio case. Might be on the left or right side of the radio. Let the radio warm up as it might be a tube radio. Next extend the antenna to full length. tune to the weakest station between 12 and 16 on the radio dial. Turn the volume down until you can barley hear the station. Next turn the trimmer screw either way until peak volume is reached. thats how you would trim the antenna if it is all in working order.
Buzz44,
It is considerably less likely that you have a bad tube.
The first and easiest (not to mention cheapest) step is to replace all paper and electrolytic caps with fresh electrolytics. Take note of their orientation as you remove them (electrolytic caps are polarized), look up the values (they should be stamped on the capacitors that you pull out), and get the equivalent valued caps at your local electronics shop.
First there are no tubes.
Now, if you have only a hum or a buzz or low audio it is most likely the old electrolytic capacitors. The link shows how to effect replacement of them complete with a diagram and then shows an easy hack to add an auxiliary input for an mp3 player.
Adding Auxiliary Input (for an mp3 player) to an Old AM Truck Radio
The next site talks about doing the same thing in a 1965 Mustang radio. While the radios might be different just reading the guys technique is where you will learn how to do it the right way. He also goes into how to pick the right replacement as we will not find an EXACT replacement. Luckily slightly higher in values is just fine.
1965 Mustang AM Radio Repair
tbm3fan: Hey, that's the instructable I posted! Thanks for linking that here.
By the way, I believe there is a chance that some of these radios do have tubes in them. I found this handy-dandy Fomoco radio lookup that can tell you exactly what you have before you crack it open:
Decoding Ford Radios and 8-Tracks
Texas Bob
08-07-2016 12:48 PM
swreutter
04-26-2006 09:31 AM
Options
10-16-2004 10:56 AM
