e150 front lift/leveling kit
I've been searching and reading through all of the post in reguards to lifting the front of a e150 i-beam. I understand the pros and cons, but still need to get this thing in the air a little. The rake is driving me crazy.
I'm not looking to jack it up 5+ inches, would settle for a mild 2-3" if possible. Would 250/350 spring do anything in raising the height? Does anyone make a coil spring spacer for the 2001 e150? I cant find any....
I know about the airbags but looking to do something along the lines of suspension to get the height and then maybe adding bags to control it later.
Thanks for the great site. The info here helped my p0401 code.....e
Well I put firestone bags in the front coils, and it allowed me to get the front end level again. Im running around 40 psi to do this. It does help with the sway and stiffened the front end slightly. It sure did make the rear spring/shock issues more noticeable. I will address that as soon as figure out the front.
I went look at a '11 e150 and notice that the front ends are level with the back from the factory. I think I'm going to bite the bullet and try new springs. We'll see what happens..
The airbag install was a piece of cake.
Crewcab Turbo
11-04-2016 06:19 AM
MongooseV8
05-09-2016 11:26 AM
