1990 f150 wipers not working
Ok im having a problem the wipers and sprayers are not working on my f150. Been google searching and can only find stuff related to the govener. They dont work on any selection on the switch and i dont see a fuse or a relay for them in the kick panel. Any one have any ideas.
on
heres a diagram for ya. thats the one in the cab. Wipers/ washers is in the #2 position. I would say its a fuse because its not likely that they both shat out at the exact same time.
Uploaded with ImageShack.us
Well....My wiper fluid sprayers seem to have a mind of their own...Sometimes they'll work, sometimes they don't.....
Swapped the fluid resevoir pump unit out, and no dice....But since my low beams side of the headlight/wiper stalk doesn't work, I am assuming its related....Seems logical to me....
Just about ready to say F it and wire the pump up on a toggle switch...
Im having the same problem with my 1994 F150. its not the fuses and its the the other fuses in the engine compartment. So I traced the wiring in my diagram and it lead me to the pulse board/governor/relay. Whatever you wanna call it. turns out, mine is fried. Im notorious for using southern engineering with electrical things to make stuff happen. I cant do that with this. It just wont work. That specific part is $120 brand new. So Im just gonna go to a junk yard and buy one. Hope this helped. Btw, I had a 1998 F250 and it didnt have a distributer box in the engne compartment. but my 94 does. So yours might not.
phoneman91
62
03-13-2024 09:16 PM
OlBrownTruck
04-27-2017 04:02 PM
mattd860
13
05-30-2009 06:21 AM
