PCV valve location
In a valve cover opposite the oil filler, towards the back, with a line to the intake.
This is an odd one, but see how it fits into the valve cover?
Google Image Result for http://www.fordmuscleforums.com/attachments/all-ford-techboard/7481d1238343687-pcv-connection-directly-intake-manifold-pcv-f4b.jpg
More like what yours should look like. PCV goes into the hole in the right valve cover in this one:
Google Image Result for http://img.photobucket.com/albums/v234/Twistedshot101/0827082249.jpg
No.
I also suggest that you replace it with an OEM/Motorcraft PCV Valve. Do a search here in the '8-96 Forum for Technical aspect of PCV valves.
The links below are very informative.
Positive Crankcase Ventilation (PCV)
https://www.ford-trucks.com/forums/1...-location.html
