Rear Window Panels won't Open
For almost as long as I have owned my EX the rear fold out windows have worked intermittently. Seems like the temperature and humidity creates a seal that the motor cannot overcome.
Anyway, for the last two weeks neither side will open. I can hear the motor click but the window will not open even if I am applying some pressure on the window while my wife works the controls.
In the past I have lubed the window seals with silicon spray. Sometimes the windows will open when driving but not when idling in the drive way...now nothing.
Any ideas?
Any ideas?
Temporarily Fixed Again!
So I used a putty knife and gently freed the rubber molding from the side panel glass on both sides. Voila! The motors open the windows again.
Once again i have put silicone lub on the rubber. Any better ideas for a permenent fix?
Just so your idea for cleaing the contacts. i think I will try that next.
Thanks
Thanks
Maybe try rain-X on the INSIDE of the window around the edges
so it won't stick?
Thankfully, I've only had 1-time when they would not open,
just after starting my PSD (alternator not "on" yet until GPs turn off).
Once the alternator kicked in they opened, so it might need
13+ volts to open when they are "sticky".
so it won't stick?
I've had this problem too... but it was my motor not making good contact (electrically). A little spray of WD40 (in a rush), and eventually it again worked. This was the side I rarely use (spare tire side).
Now my fix; To occasionally open that side. Maybe a few times a week.
Thanks
Thanks
