1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How Long Will a New Battery Last with Bad Alternator
Old 01-12-2011, 04:00 PM
StangPullerF250's Avatar
StangPullerF250
StangPullerF250 is offline
My truck is stranded at Target and I really don't feel like getting it towed. I want to get a new battery anyways since its over 8 years old. If the alternator is bad, can I make it home from a 30 minute highway commute? I know dumb question, I would just rather replace the alternator at home (if that is the problem) than trying to do it in the dark at Target.
Old 01-12-2011, 04:05 PM
Byram's Avatar
Byram
Byram is offline
Remember the more electric you use - the quicker it will die.. Headlights, Blower motor, radio etcc....
jim6liter's Avatar
jim6liter
jim6liter is offline
you'll make it.Don't use your headlights and keep the stereo off.
Old 01-12-2011, 04:12 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
I made it about 2hrs a truck with a bad altenator. The 05+ gasser and the 6.0 + trucks will shift really erratically if the voltage gets low just a fyi.
Old 01-12-2011, 04:29 PM
seminaryranger's Avatar
seminaryranger
seminaryranger is offline
Yeah, you should be fine to make it 30 min with a fresh battery.
When installing it, I'd supplement it with a jump from whoever is giving you a ride. In other words put the battery in your truck, connect everything, and hook up a set of jumper cables to another running vehicle while you start it. This will give you a little extra juice to make it home.
While you're driving home, minimize all electrical drain.
No stereo.
No electric windows.
No fiddling with the electric seats.
No headlights in daytime.
No HVAC
The truck's computer and auto transmission use a fair bit of juice just to operate the necessary functions needed to keep the engine running and transmission shifting.
You should be fine.
Old 01-12-2011, 04:40 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
I would say it will be close as new batteries usually don't have a full charge..
Old 01-12-2011, 07:24 PM
StangPullerF250
FYI I made it home. I think it just needed a new battery. I'm going to see if it starts in the morning. Thanks Everybody.
Old 01-12-2011, 07:29 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
please check both batteries! Diesels needs two fresh units with a working alternator.
Have them load tested, one good battery will be drained by bad battery
have alternator tested as well. Most new alternator will have a lifetime warranty
Old 01-12-2011, 08:02 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Reserve capacity is always posted for a new battery, but the test load is probably less than your actual load.. so do some calculation:
Battery Tutorial
Cold cranking amps (CCA) is a measurement of the number of amps a battery can deliver at 0 ° F for 30 seconds and not drop below 7.2 volts. So a high CCA battery rating is especially important in starting battery applications, and in cold weather.This measurement is not particularly important in Deep cycle batteries, though it is the most commonly 'known' battery measurement.
CA is cranking amps measured at 32 degrees F. This rating is also called marine cranking amps (MCA). Hot cranking amps (HCA) is seldom used any longer but is measured at 80 ° F.
Reserve Capacity (RC) is a very important rating. This is the number of minutes a fully charged battery at 80 ° F will discharge 25 amps until the battery drops below 10.5 volts.
An amp hour (AH) is a rating usually found on deep cycle batteries. If a battery is rated at 100 amp hours it should deliver 5 amps for 20 hours, 20 amps for 5 hours, etc.
If you have a 50 amp load (600 watt) typical of a diesel with nothing else on... no ac no lights, etc...
You have the minutes battery says... less about 25% based on state of charge and error ....
Old 01-12-2011, 09:11 PM
CraigOutdoors's Avatar
CraigOutdoors
CraigOutdoors is offline
I've been told that a bad battery will kill an alternator and vice versa. I know that I have had a battery go bad and the alternator went suspiciously soon thereafter a couple of times. Confirmed both were bad with testers, not the replace and hey now it works method. To be on the safe side, you might pull the alternator and have it tested just to see. All the parts shops around here will do it free.
Old 05-05-2011, 10:16 PM
mavrik4x4's Avatar
mavrik4x4
mavrik4x4 is offline
At least 20miles@3am coming home from the bar. With the last 5mi w/out headlights. Enjoy!lol
akvalentine977
Electrical Systems/Wiring
13
01-20-2020 07:14 AM
bluzzer
58
11-01-2016 11:43 AM
thegreatgate
05-08-2016 12:59 PM
651_F350_KR
04-26-2016 09:01 AM
ScottInTexas
2004 - 2008 F150
12-31-2015 09:01 AM
Quick Reply: How Long Will a New Battery Last with Bad Alternator
