DTC 1211 on stock PDS under load.
Ok, I've lurked here for a long time and have a few questions. I've researched the crap out of the 1211 DTC, but haven't found one with a stock truck! (I must be slow...). Anyway, Here's how I pulled it:
Towing a large 8K trailer up a large grade. Every time I go up a large grade with a very heavy load, it shows a 1211 code. Everything else seems to be running find. So from what I have learned I need to replace the ICP o-rings, and possibly the HPOP o-rings. So a question is: does this sound like it might fix the code?
I don't lose power. No chip or aftermarket part except an air intake. No noticble loss in power or black smoke.
Also if I get new HPOP o-rings do I HAVE to pull the HPOP off the engine and buy a new gasket, or can I replace them all while it is still on the engine and not buy the gasket?
Thanks in advance,
Ryan
Thanks in advance,
Ryan
Welcome to FTE. Glad to see you posting instead of just lurking.
First question is what are you using to pull the codes? Can it monitor any live data?
Next, tell us about the engine oil. How many miles since the oil change? What brand & weight of oil? Any additives? Is it full?
I believe you're talking about IPR o-rings instead of ICP. I don't think that's your problem if the truck seems to run and start fine. Likewise, I wouldn't mess with HPOP o-rings unless one of them is leaking. Injector o-rings MIGHT be a possibility, but if they're leaking you'll often find a trace of oil in the bottom of the fuel bowl filter so check that.
The code is being set because the truck is trying a little harder than the computer thinks it should to perform like you're asking it to. Typically when IPR duty cycle starts to go above 50% or so. It maxes out around 64% so you've got spare capacity which is why you don't notice any performance issues.
I would suggest you figure out how much strain, acceleration or load you have to put on the motor before the light comes on and then just keep an eye on it. If the light starts to come on sooner or with less of a load, it's time to monitor some live data and figure out what's wrong. If it doesn't get worse, it may be something you can live with for a while.
2000 miles is all. I use a programmer I use on my ford lightning. I don't know if it will datalof since it's 'assigned' to another truck.
Also, I wouldn't say I'm totally pushing it. I have it at 80-90% of throttle when it engine check light.
I use rotella 20-50. No additives. And it is full.
I will need to check fuel bowl and see if I can data log. I'll have to plug it in and see what happens on data log screen.... Oh yeah what am I watching again if I can?
on
Shell Oil Lubricants - motoroil.htm
Okay so here is the update. I found no oil in my fuel filter. I have bought a scanner that does real time data. I recently replaced my ice sensor and it still reports exactly the same.
My icp is showing anywhere from 500's when idling and goes up to 2000's when driving. Although I see my ipr going up to 80's when getting on it with no load.
I'm now hoping it is a bad ipr valve and plan to pull it out today and see if I can spray brake cleaner into it. I hear they normally just get dirt in there... I'm rally hoping its not a bad hpop.
I did notice that when I off the gas on a harder run when the ipr and icp are pretty high 80-90 ipr and 2800icp and the icp will momentarily shoot up to 3500's
I'm hoping that means the oil pump is not bad. It still runs fine, starts fine too. I've also found its easier to get the code to throw when I have my 80 hp chip set so ive been doing most of my testing with that chip and that is how I get the numbers I have seen
Your IPR is not supposed to go high enough to reach the 80's so that's what's tripping the P1211. What kind of ICP psi are you reading when the IPR gets that high and exactly what kind of load are you putting on it?
Also FYI, this P1211 isn't any impending disaster. It simply means the computer is asking for more power than certain parts are delivering. I'm assuming the light goes out after a couple of minutes of normal driving? It's something you can easily live with for a while.
Ipr bad - YouTubeIf a picture is worth a thousand words, how much is. A video worth? Watch from 30-50 seconds. This is wot and no trailer.
Mine is doing the same thing.
https://www.ford-trucks.com/forums/1...lp-please.html
You can spend a pile of money on big oil or injectors to fix it, or just live with it for a while. It really should not be doing it with stock tuneing though. I would try a new IPR. It does not hurt to have a spare if that is not the problem.
Keep us posted.
Keep us posted.
How does it start when the engine is warm.
You may have a leaking injector oring.
Do a search for how to pressure test the heads. If you have one head leaking HPO pressure, that will at least narrow the search to which oring is leaking. Other signs of a pressure leak are oil in the bottom of the fuel bowl, and oil consumption that may have just recently started.
Bumping this old thread. So since I've posted I've done a few things. I only drive this truck on vacations so I'm only reminded of trouble when I use it... So that's why I'm so slow to fix/report issues.
I replaced the icp, ipr, and put in a t500 hpop. My icp/ipr are still showing 22-2400lbs and 89.6 duty cycle on big hills. Truck pulls fine but man this is getting annoying and expensive. I did add a chip which gives more power but still seems to throw code 1211.
Every other guage seems to be within specifications... On to injectors I guess. Any advise would be appreciated.
