TTB 44 or 50 swap to straight Dana 44
Old 05-02-2011, 11:50 PM
jackdaniels250's Avatar
jackdaniels250
jackdaniels250 is offline
I have a 1981 ford f250 4x4 with a 400m and C-6 trans. Im building a mudtruck out of it and it currently has the TTB front suspension. Im wondering if its the Dana 44 IFS or the Dana 50 IFS or what do i look for to tell what it is for sure. Now id like to do a solid axle swap and i found a Dana 44 straight axle for a decent price. The guy selling it says its out of a 1989 f250 4x4, it is complete except for the hubs. Im wondering if my truck does have the Dana 44 IFS front end would my hubs, bearings and brakes fit onto this Dana 44 straight axle.
Old 05-03-2011, 12:53 AM
glovemeister's Avatar
glovemeister
glovemeister is offline
I can't remember the particulars except that a 44 straight Dana isn't much stronger than a Dana 50 ttb. TTB isn't really independent by my definition more like solid halfshafts.
Old 05-03-2011, 12:55 AM
glovemeister
This link will tell you everything you need to know about TTB and swaps. https://www.ford-trucks.com/forums/1...tb-thread.html
Old 05-03-2011, 12:50 PM
dohc_chump's Avatar
dohc_chump
dohc_chump is offline
This space for rent...
How big a tire are you planning on running?
The straight axle is no stronger than the TTB D44 in stock form. The only real difference is the extra u-joint in the axle shaft. You can upgrade the TTB D44 with a D50 inner axle stub and step up to a larger inner u-joint if you're dealing with breakage there. Theoretically speaking a TTB D44 should handle 35" tires, a straight axle D44 again, 35" tires unless you start upgrading, and a TTB D50 should handle up to a 37" tire. If you want to go bigger you need to step up to a D60, D70, Rocks, or portals.
Also, it was just recently asked about what parts swap between the two. Long story short: lockouts, calipers, center chunk (bearings included) are all you can use. Rotors may or may not fit depending on years.
So honestly, a D44 straight axle isn't going to do diddly for you in the mud without upgrading it. I'd personally run what you have now and save for better upgrades in the future. There's no point in spending money for a lateral movement.
Old 05-03-2011, 04:33 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Just a FYI no f250 from 80-97 came with a solid axle
KingProvince
05-20-2017 11:47 PM
Johno.h
11-12-2016 04:18 AM
1984_IH6.9_Project
23
11-10-2016 08:36 AM
nonrev321
09-01-2012 08:09 PM
sharker98
11-12-2003 12:03 PM
Quick Reply: TTB 44 or 50 swap to straight Dana 44
