73 F100 Rear Wheel Bearing and Seal?
Can someone tell me which axle this is in the pic? The axle code on the VIN Tag is H2 and the rear axle GVWR is 3218. It has an oil seal about 2 inches inside the axle tube. I don't see any seal on the outside of the bearing. Are these bearings a sealed/prelubed bearing? Would these be ball bearing or tapered bearings? If I just replace the seal inside the axle tube, would that stop a leak or is there something I am missing here. As far as I know this is exactly as it came from the factory. VIN is F10YRQxxxx with 133 inch wheelbaseHere goes with my first attempt to link a pic.....
http://www.orionscitech.com/CarRestorationPics.html
Not sure about how it gets lube.. The seal is between the bearing and the differential so no lube can get through to it... I see that Napa Online lists a bearing that looks the same and it says it is sealed.. So, guessing it is a sealed and pre-lubed bearing so it doesn't need any diff lube getting to it...
This is the early style bearing. It is a sealed ball bearing and does not use the gear oil in the axle housing for lube. As you said, the seal is pressed in the axle tube first, inboard of the bearing. This is the only seal.
The later style tapered bearing (often reffered to as "set 20" bearings) do use diff. oil for lubrication and the seal goes outboard of the bearing.
The first reference in the Ford parts catalog to the tapered bearing is '74.
D4AZ-1225-A .. Tapered Roller Axle Bearing/Seal combination / BIN: U-399-A
D4AZ-1177-A .. Seal only.
D8AZ-1225-C (replaced D8AZ-1225-B, C9AZ-1225-A & C1SZ-1225-A) .. Axle Ball Bearing-Large / BIN: F-208-HL
EOTZ-1S177-CA (replaced C9AZ-1177-A & B7A-1177-A) .. Axle Seal.
BIN: Bearing Industry Number, marked on the parts, and are what autoparts stores go by.
Thanks all for the help and info... I did check the axle vent first thing... It was open but restricted so I pulled it off and cleaned it out.. Putting on a new hose since everything is factory original and the old hose is brittle...
Just one more question. When I pulled the axle out, I was able to just grab it and pull without having to use a puller on it.. It came out pretty easy.. Is that normal or should it have somewhat of a pressed in feeling to it?
Thanks again...
Thanks again...
