Bolt Pattern on 2011 F-250
Hola, and Welcome to FTE!
8 on 170mm, same as every other SRW Super Duty. Factory backspacing and front suspensions were changed in 2003, wheels smaller than 17 inches won't work on trucks after 2005. All factory wheels are hub-centric, so watch out for lug centric aftermarket wheels, they use acorn lug nuts and not the factory flanged nuts.
Yeah, the earlier wheels, and only those 17" and larger, will stick out about 2" more on the '05+ trucks. The '05+ wheels will fit on the earlier trucks, but they will sit in too far and look goofy. Also, wheel spacers are NOT advised, except maybe if you use the machined steel ones, and those cost almost as much as a set of wheels.
Comanche1Star
10-05-2010 01:11 PM
twinpeaks
01-30-2010 06:28 PM
