Truck/Trailer wiring all fugged up...
Old 04-27-2011, 10:13 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
I got a neat little trailer yesterday, went straight to O' Reilly's, and bought a matching 4 pin/flat connector...
I THOUGHT it was going to be straightforward....But No.....
I can get either stop lamps and NO turnsignals....OR .....Turn signals and NO stop lamps....And I REALLY need both....
The tail lights on the trailer, has the standard 4'' lenses, and a have a smaller, 2" x 2" lens on the outer side....
The stoplamps have 3 wires in them-
White-Ground-It's already grounded to the trailer frame
Gray
Brown/Grayish
and the smaller lenses have just a single gray wire from it (It is on a common ground plate with the stop lamps)...
My question is, on the 4 pin connector (Trailer side) it has the following color coded wires
Black-Ground
Black w/ Green Stripe-Right Turn Signal
Black w/ Yellow Stripe-Left Turn Signal
Brown-Stop lamps
Do I wire the brown (Stoplamps) wire to each of the turn signal wires? Or will that short the system out?
All help is greatly appreciated....Reps WILL be sent for this.....
-Wes
Old 04-27-2011, 10:41 AM
subford's Avatar
subford
subford is offline
Brown is the Marker lamps (running lights), not stop lights.
The turn wires are also the stop lamp wires.
Old 04-27-2011, 10:44 AM
SideWinder4.9l
I stand corrected....Will they function like the regular taillamps o a truck? Marker/Brakes/Turnsignals?
Thats what i am looking to get accomplished.....Is that how they are supposed to function?
Old 04-27-2011, 03:48 PM
subford's Avatar
subford
subford is offline
Yes it is.
Do you need a diagram?
Here is one:
Old 04-27-2011, 03:51 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
depending on your hitch type and trailer connector (assumeing standered 4 pin trailer) and your truck if its an RV hook up will either be a 6 pin or 7 pin (mine is 6 pin) you could go to your local Uhaul place and get the proper adapter for your hitch/trailer as I had a similar issue where I need to go from 6pin RV to 4 pin trailer.
Old 04-27-2011, 04:35 PM
SideWinder4.9l
Thanks for the diagram Bill....
I actually googled it, and now its fixed....
bigbubba87
13
11-07-2023 11:14 AM
1fixitman
06-06-2018 07:20 AM
wrenchhead428
10-16-2015 03:35 PM
SEAL1
07-13-2015 05:30 PM
cherrybomb37
12-03-2014 11:44 AM
Quick Reply: Truck/Trailer wiring all fugged up...
