Trailer lights not working
I've noticed that with all my trailers that when im running my lights(driving at night) the trailer lights dont illuminate, The brake, and turn signal light all work. So since its happening between several trailers im guessing i have a bad fuse. What fuse would this be? This is on my 05 250 btw. When towing these same trailers with my 350 the lights work fine.
I would start by using a small pick that has a 90 degree bend in it to re bend out the pins on your trailer light socket on the truck. These pins wear down and bend closed so they don't interact with the trailer plug as well as they used to.
This happens more and more the more the trailer light socket is used.
After this I would start with a volt meter, seeing as you have already checked the fuse.
kirkharrod
06-06-2017 12:53 AM
