10.25" hub seal
10.25" hub seal
I'm frustrated right now trying to pull a leaking hub seal out of my Sterling 10.25 without trashing the bearing.
I have broken the hook on my slide hammer, and welded it up and broken it again.
Bent a 3' Matco prybar.
Torched all the rubber lip off the seal.
It doesn't seem I can punch it out from the other side with the bearing in place.
I think it's too solid to collapse it in on itself.
Does anyone here have an easy out for me?
It's time for dinner and a cocktail...
Any and all ideas are welcome.
Thanks!
Thanks!
Did this job on my buddy's '97 250 HD a couple years ago, and it went pretty easy IIRC.
Just throwing it out there...any chance you could carefully cut a section of the seal out with a Dremel? I think a cutoff wheel would be too big unless it was REALLY worn down.
Sorry for the dearth of ideas...good luck!
Pat
Pat
Bill, The inner race and bearing won't allow me to use a punch from the other side.
I REALLY took a rosebud torch to the hub and worked it out with the 3' prybar.
That smoking hot seal shot out and hit the 14' ceiling then bounced around.
Stupidly, I grabbed it...
Couldn't find a torque spec for the Sterling 10.25" full floater so I just cranked it down tight and backed off 1/4 turn.
Still seemed tight, but I assume this was the new seal. (I did pre-lube it with a bit of 90w)
Federal-Mogul brand was in stock locally so that's what I used.
I just finished and am ready for a test drive.
Hope this goes well.
Jim, from TSB 91-6-7:
"Caution: The specified torquing and backing of the hub nut is critical in order to perform the repair correctly."
"Note: Always turn the hub while tightening the hub nut. Once the specified torque 55-65 Lb.Ft., (75-88 N-m) is achieved, ratcheting back on the hub nut varies depending on whether the hub bearings are new or used. Back off 5 clicks for new bearing and 8 clicks for used bearings."
TSB 94-19-24 addresses a seal modification that was incorporated in the 94 model year and is serviced in a kit F4TZ-1177-C
quakerj
03-02-2015 07:03 PM
Fullcrew7.3
06-27-2011 09:17 AM
nookiemonster55
11-17-2010 05:53 PM
buck_
19
09-23-2006 09:13 PM
