1995 F350 Brake Bleeding Problem
'95 F350 with rear ABS only.
Replaced front calipers with Cardone remans. Bled with buddy system until no bubbles, pedal is hard. Turn on truck and pedal becomes very soft eventually going to the floor. Removed front brake line from master cylinder and plugged the MC port and pedal becomes as hard as a rock with engine off or on so MC appears to be good indicating there is still some air trapped in the front hydrolics somewhere.
Anybody have any ideas on how I can get the air out of the system and get this pedal to harden up? I'm using ATE Super Blue brake fluid.
Thanks in advance for any help-
Welcome to FTE.
Did you just bleed the front? Start with the farthest one away from the master cylinder?
Air could have worked it's way into the rear lines through the proportioning valve. I'd bleed all four corners, starting with the farthest away and working your way to the closest.
Keep bleeding them, there's air in there somewhere.
Thanks for the input guys. The bleeders are at the top of the calipers.
I'll hit it again today. Maybe bribing my wife with dinner out tonight will keep her in the cab exercising her left leg.
I have a MityVac 8000 I think it is, but whenever I crack the bleeder it just sucks air from around the threads. The pedal pump method seems to push the most fluid.
Thanks again-
Thanks again-
No not really. You can get it fairly close by bleeding it through the brake line itself but you'll still most likely have air in the caliper. It would be good enough if you need to go after parts or whatever but I wouldn't leave it that way.
Received 3,108 Likes
on
