Blown front seal E4OD
Old 04-21-2011, 01:48 PM
avenge's Avatar
avenge
avenge is offline
What would cause to a front seal to blow out? I just put in a used front pump with new seals, bearing and gasket. The pump came out of my other transmission that had a torque converter go out. After it was done it was dry as a bone only thing I noticed was a slight vibration in drive when stopped.
Would a bad or blocked pump (drain back valve) cause it? What about a blocked cooler line or backwards cooler line?
Anyone know which side of the radiator on a 95 E150 van is the trans return line?
I ask because I had to cut the lines and forgot to mark which was which but thought I guessed right and also heard it made no difference.
quaddriver
07-13-2023 08:19 AM
johnsland8
1999 to 2016 Super Duty
02-21-2016 07:59 PM
UrMedic
01-21-2016 07:12 AM
carver94f350
N. California Chapter
10-21-2015 02:29 PM
Bread
03-07-2012 10:11 AM
Quick Reply: Blown front seal E4OD
