EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
How to change the oil filter.
Old 04-19-2011, 12:05 PM
drh1175's Avatar
drh1175
drh1175 is offline
I was under my new truck trying to figure out how to change the oil when it is time. I figured out how to gain access to the drain plug. But what about the filter? Anyone tried yet?
Old 04-26-2011, 10:19 PM
jimmyb08SD's Avatar
jimmyb08SD
jimmyb08SD is offline
Yep in the front between the metal pan and the bumper is a rubber filler, the drivers side has the plastic twist clips which opens that side up. the filter is up in there a little bit but pretty easy to get to. You will notice there is a pan under the filter which funnels the oil out to the front, Caution- loosen filter slowly and let drain slowly for a few min., if you open to fast the pan will overflow and make a mess all down in the metal pan.
Joseph Burke
02-24-2017 03:26 PM
SRSherrill75
6.4L Power Stroke Diesel
03-04-2016 07:44 PM
scotthud1321
02-19-2016 11:16 AM
fordtruck661
10-22-2011 08:44 PM
ptd0647
09-08-2003 08:39 PM
Quick Reply: How to change the oil filter.
