Old 11-12-2014, 06:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
Print Wikipost
how to change fuel filter?
Old 04-17-2011, 09:01 PM
93 mix 'n match's Avatar
93 mix 'n match
93 mix 'n match is offline
how do i change my fuel filter? i was told certain tools were needed?
Old 04-17-2011, 09:18 PM
fordf150farmer's Avatar
fordf150farmer
fordf150farmer is offline
How To's on changing fuel filter? - F150online Forums
every thing you need right here ^^^
any auto parts store should have the tool you need like 5 bucks for the package
Old 04-17-2011, 09:29 PM
sport truck xl's Avatar
sport truck xl
sport truck xl is offline
fuel line removal tool at any auto parts store they run about $8
Old 04-17-2011, 10:00 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
I didn't read the full 6 pages on the "How To" link but you should relieve the fuel pressure first before attempting to change the filter. 45 psi 'approx' fuel pressure can do harm to you if it hits your face, eyes, hot exhaust pipes, etc. Just pull the fuel pump fuse, crank the engine over a few seconds, it won't start. Turn key off, reinstall fuse, change your filter. Even after relieving fuel pressure there will be residual fuel in lines leaking when removing the filter, so have rags handy and be safe.
Old 04-18-2011, 08:52 PM
93 mix 'n match
so, new problem. cant get the lines off. got the tool, it slides in, but they lines wont pop off!! i can twist them, but they just wont pop off.
Old 04-19-2011, 09:10 AM
meierw1's Avatar
meierw1
meierw1 is offline
Had the same problem with mine, take some wd or pb blaster and spray it in the ends and sit there and work it slowly or you woll end up breaking the line and having to replace it.
Old 04-19-2011, 10:48 AM
jgeese's Avatar
jgeese
jgeese is offline
From my experience the plastic tools don't work very well. Asked at the parts store for something more substantial and they had a metal tool that looked like scissors that had a shaped cup at each end to fit over the fuel line with each end a different diam. Gives far more leverage and something to push with in tight quarters!
Hope that helps...
Old 04-19-2011, 03:07 PM
sport truck xl
I agree, use the metal tool and just use steady pressure pushing on the tool with one hand and pulling the fuel line with the other.
Old 04-19-2011, 08:18 PM
93 mix 'n match
what size is the line so i know what size to get?
Old 04-19-2011, 10:47 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
Sometimes there's dirt/rust forms inside the connection. Try spraying it out with wd as suggested above. In a kind of awkward movement for one hand, I have the tool positioned on the line, then I try pushing the line into the filter, then I press the tool into the connection. I then tug/twist on the line with the tool still pressed in while holding the filter with the other hand. I have used both the nylon and steel scissor tool as mentioned in other reply but prefer the steel tool better.
The scissor tool is made for two different line sizes.
brother steve
6.7L Power Stroke Diesel
15
10-29-2015 02:24 PM
Dustball8504
09-02-2015 05:58 AM
Bvill01
21
10-09-2012 06:41 AM
IQ9
03-19-2012 11:10 AM
'94IDITurbo7.3
20
03-08-2012 10:14 PM
Quick Reply: how to change fuel filter?
