Starter Removal
If it's the typical early Ford starter, the two thru-bolts you'll see on the end of the starter towards the front end are what holds it in. Be careful taking it out, the starter can come apart if you just pull on the front end.
Edit: maybe not -- should have looked at the Parts CD first. I would guess there are actually 3 bolts, based on location of the 2 you can see
