Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How to Change Brake Rotor
Step by step instructions for do-it-yourself repairs
- How To Replace Emergency Brake
Parking Brake Backing Plate Installation - WITH PICTURES
#46
Here's pic's of my plate change. They were toast. The paint on the plates wasn't up to my spec's so a light sand blast and 2 coats of rust bullet..I'm going to get new pins tomorrow because they are way too short that came with the plates and also that came in my spring kit. I had an old subaru one that was 1/8 longer that worked great so I have to hunt them down. as you can see I have an early 99 with the caliper in front on drivers side. Had to get two right plates. Called Carl from Dorman and he worked with me and my parts store..Tomorrow all goes back together. I used new hub seals and a new oring on the axle..
Dick
Dick
#47
Roger that for the 99, I needed 2x r/h plates....ended up modifying the lh to a rh configuration. The Dorman kit was not bad quality and came with rubber boots and pb shoe retainers. Too bad the kit didn't have 2x rh for my installation. My fix was a little bubba (no offense to anyone of that name ) What torque is used for the backing plate retainer bolts? I cant seem to find it. I just torqued mine up to 'alot'.
#48
Just tighten em down really good with 1/2 ratchet not really important..just holds the caliper LOL
To anyone else they might want to call Dorman to see if they will work with you.
1800-868-5777 ext5172 Jim... Tell him you need two right plates for early 99 with dr caliper on front of axle.
Dick
Dick
#50
Thanks for the write up!
I am so glad you did this. I just checked the brakes on my 05 that I bought used last February and found first the front had the wrong size rotors on it. They were to small so I assumed someone put rear rotors on the front. When I checked the back brakes I had a big surprise. The brake backing plate had rusted so bad that the parking brake retaining pins had pulled through and the parking brake pad on one side was rubbing against the heads of the wheel studs. It cut groves in each stud. Both sides were like that. Also the slide pins were frozen in the caliper mounting bracket on the drivers side front and rear. I need my truck so for now I just removed the parking brakes but now that I found this I will try to get the parts and fix it over the holiday weekend. Great write up!
#51
I was just into mine and my backing plates look like yours so time to change them...
Great article good job!
My book says: For new bearings, ratchet back five teeth or notches (1/8 turn) on the hub nut. Five notches must be felt during this operation in order to have performed it correctly.
For used bearings, ratchet back seven teeth or notches (1/6 turn) on the hub nut. Seven notches must be felt during this operation to have performed it correctly.
Is this the same as your source or is 99 different or did ford update it?
Dick
Dick
Nice write up and pics. I hadn't seen this thread before and just replaced mine last night and took a bunch of pics. They were actually in pretty good shape - well, until truck was stolen and when they recovered it the wheels/tires were gone so it got dragged up on the slideback and the backing plates were pretty much destroyed.
Dealer had them as full-assemblies which was pretty nice for the installation-side of things!!
However, this part of the instructions that say to back the nut 5 clicks or 7 clicks. Back it from what? Cuz they click about 30 times putting them on!!! The guy ran them until the axle rotation began to drag them backed them off...
#52
#53
Found this So Happy!!!!!!!
After finding this I made my decision to do this repair myself. Talked to dealer and they wanted $311.00 for the complete set up for one side. Found the plate for both sides for $67.00 at Oriellys then went to Rock Auto found them for $47.89. then I went to Oriellys and they price matched the parts so I bought the pates and shoes and hardware kit for $83.00 Thank for this Info!!!!
#54
gonna change the plates
Thanks for the video. I would like to know the size of the big socket to unscrew the bearing and the size of the puller needed. I will pack the space in between the two plates with Shell waterproof grease I think it is 2000 extreme.. And the name of that big socket . thank you again for the interesting and complete video.
#56
My Parking Brake Backing Plate was looking a little rough, but good enough to use again. I cleaned it up and used BBQ paint because of its robust qualities.
I must add that the parking brake lever ("lever thingy") is usually the culprit in sticking parking brakes. I replaced that hardware, but it wasn't real cheap.
#57
Thank you.. would you know the size of the three finger puller so I could buy it at Harbor Freight Tools.. I'm still dreaming of SSbacking plates.
#58
#59
#60
