Mission creep and trans cooler
My new to me toy ('74 f100) has a radiator with damp spots, intake that leaks at the China walls, and a transmission that needs a filter change. So I have been putting a parts pile together. Champion radiator (the front support will need cut but I get more radiator), gaskets and filters and such. My question is does this 302/c4 need an auxiliary trans cooler? I'm believing you can't over cool trans fluid. It might get to pull a load from time to time.
The cooler is a good idea. Also agree mount the auxiliary cooler on the cold side of the radiator cooler for best results.
You can tell the "hot" line by where it comes out of the transmission case. I do not know which is which on a C4.
There is another way to check. Start the truck dead cold. Put it in drive for 10 seconds then shut it off. Then feel the trans cooler lines going into the radiator. The warmer line is the "hot" line and should stay attached to the radiator cooler. The other gets the auxiliary cooler in series.
Derale aux cooler uses a spal fan and although I installed to cool a 6R80 6 speed it worked extremely well. Mounted under the drivers seat with isolators to keep it quiet and used -10AN lines. I fabricated a small deflector shield for rocks that may be kicked up by the drivers front tire and installed a trans temp gauge to keep an eye on it. My rationale was if one was hauling anything significant, especially up a hill or stop and go traffic where your speed decreases the radiator fan has to cool both the truck and the trans as ram air would be at a minimum thus an aux cooler could help and I live in Arizona so I had the radiator to keep the engine cool and not pull hot air off the trans cooler directly into the radiator. Cheap insurance on the very hot days.
The following users liked this post:
That's a thought, but in really hot pulls in the summer, seams it would get hot on / under my Wife if I were to put the trans cooler under her seat. I mighrt would soon become uncomfortable as a result.
As to the thread ... mine is hanging between the radiator and fan, is plumbed into return line to transmission.
Truckman8719
07-23-2018 05:49 PM
Aaron-71
08-17-2015 02:26 PM
BIGFISH70
06-19-2007 10:07 AM
