Possible fuel pump problems.
Old 04-12-2011, 06:40 PM
Firemudder's Avatar
Firemudder
Firemudder is offline
For the past few months I have been having a problem with my fuel getting to a quarter tank. The truck runs great until I get to a quarter then starts to chug like its running out of fuel. It also has shut off before due to the same problem, then fires up with more fuel.
I have replaced my filters every 15 thousand and ran a couple bottle of diesel kleen but still have the issue. Also I drain the filers housing often and make sure I get fuel from busy stations.
I know its not great to run the tank low but sometimes it happens. Any advice would be greatly appreciative.
Thank.
Old 04-12-2011, 08:01 PM
steelhead2's Avatar
steelhead2
steelhead2 is offline
I would say your fuel gauge is off by a quarter tank.
Old 04-13-2011, 05:58 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
It's either the sending unit OR the pickup in the tank. The pickup has a rubber flapper valve on the side that can sometimes open/fail and cause this problem.
Old 04-13-2011, 06:53 AM
Firemudder's Avatar
Firemudder
Thanks guys for the responses. I think I will remove the sending unit and flapper this weekend and see how it goes.
Old 04-13-2011, 07:03 AM
npccpartsman
It's also a good time to do the "Harpoon Mod" while you've got the tank off. Check out the tech folder for more info.
Old 04-13-2011, 07:25 AM
Firemudder's Avatar
Firemudder
Ok thanks I will look into that. Also thanks for the picture.
Old 12-21-2013, 11:57 AM
drgnner's Avatar
drgnner
drgnner is offline
Im having a similar problem and today I noticed that when it doesn't start, I also do not hear the fuel pump before hitting the ignition to start. I took it to ford a couple of weeks ago and they couldn't get it to fail. Intermittent problems are tough. Ill go back with this small tidbit of info.
With all of the electronics on this machine I would expect a trouble code. None given.
Beechnut
02-01-2014 11:05 PM
jsheffield88
18
05-31-2012 04:36 PM
biggyman50
10-12-2010 09:44 PM
rickatic
06-18-2010 10:11 PM
fbilly420
Modular V10 (6.8l)
06-04-2007 08:11 AM
Quick Reply: Possible fuel pump problems.
