Radio removal on my 2003 truck
Old 04-12-2011, 12:15 PM
Osideboy's Avatar
Osideboy
Osideboy is offline
Need help to remove old radio. What do I need and where can I get insructions?
Old 04-12-2011, 03:13 PM
phil6608's Avatar
phil6608
phil6608 is offline
This is the tool it take to release the clips that hold it in.
You can make your own out of a coat-hanger.
New OEM Radio Stereo Release Tool/Tools Removal Key 2 | eBay
Old 04-12-2011, 08:16 PM
wgotthardt's Avatar
wgotthardt
wgotthardt is offline
YouTube - Ford Car Stereo Removal and Others
I recommend the $2 tool(s), they are spring steel with ends that snap in place to the correct depth, with a coat hanger you'll be fishing around...but yeah it'll work if you have an idea how the clips are situated.
Old 04-13-2011, 11:36 AM
artfd's Avatar
artfd
artfd is offline
Exclamation
On the other hand, if you don't know how the clips are situated, you may not get them to work properly. I found it easier to disassemble my dashboard, and I needed to do some other things behind it anyway. Once I had the dashboard apart, it was easy to see how the clips were supposed to work. If you have never seen them before, never worked the tool, it may not work for you. Good luck.
Old 04-13-2011, 09:44 PM
Osideboy's Avatar
Osideboy
Osideboy is offline
Thanks I was able to get a tool from e-bay, and I also watched the vedio to see how it is done thanks to everyone who helped.
Old 04-13-2011, 09:45 PM
Osideboy's Avatar
Osideboy
Osideboy is offline
Thanks for your help I am able to switch out my radio.
Old 04-14-2011, 02:10 AM
phil6608's Avatar
phil6608
phil6608 is offline
Good job.
I need to get one myself.
I about broke something the last time changing my radio without it.
I'll never do that again,,soooo much easier with the tool!
Old 04-14-2011, 04:04 PM
Osideboy's Avatar
Osideboy
Osideboy is offline
What is a (DIN)
I have read where people talk about a DIN or double DIN and I ask myself, what the heck are they taking about? I have an idea it has to do with radio equipment, but don't have an idea.
Old 04-14-2011, 05:21 PM
phil6608's Avatar
phil6608
phil6608 is offline
Old 04-21-2011, 10:16 PM
chopped&dropped's Avatar
chopped&dropped
chopped&dropped is offline
Oside boy DIN is the normal size of a radio
DOUBLE DIN is the thickness of 2 radios
id suggest you pull ur radio out and if the back comes out a little bit then dips down then you will know you have a din and a half let me know if you have anymore questions and i can see some pics
MRCSUSN2007
01-10-2014 08:14 AM
dfooch
1999 to 2016 Super Duty
08-24-2010 10:25 PM
Boonebird
20
04-02-2008 07:08 PM
PickSty
04-16-2004 10:07 PM
Quick Reply: Radio removal on my 2003 truck
