04 6.0 oil & egr location
Old 04-11-2011, 04:37 PM
350crew4x4's Avatar
350crew4x4
350crew4x4 is offline
Looked thru the tech folder, if it's there i missed it.I'm looking for the location of both of these looking at some kits and the oil cooler kit doesent come with intake gaskets. I'm new to diesels but not to turning a wrench any help would be appreciated. Also are there other thing that I should do while I'm in there.
Thanks
Old 04-11-2011, 04:51 PM
nylyon's Avatar
nylyon
nylyon is offline
The oil cooler is directly under the oil and fuel filter assemblies, as they actually bolt to the top of the oil cooler housing. The EGR cooler runs on the underside of the intake manifold on the passenger side. Yours will either be square or round depending on if you have an 03 motor in your 04 or not. The gaskets are reusable, but I did replace them the first time I replaced the oil cooler. A lot of guys also replace the turbo drain tube and fuel pressure regulator while in that deep.
Old 04-11-2011, 04:55 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Here you go for the EGR cooler:
From this manual:
Powerstroke 6.0L Technical Intro Manual
And a picture of the hose that connects the oil cooler to the EGR cooler. The thing with the #'s on it is the EGR cooler.
Old 04-15-2011, 08:03 AM
350crew4x4's Avatar
350crew4x4
thanks that helps, I will finally have time to woork on it this coming week.
When I got the truck back it has a massive oil leak now that the mechanic told me was the oil cooler I'm wondering what would cause this ?
Old 04-15-2011, 09:13 AM
tharepairguy's Avatar
tharepairguy
tharepairguy is offline
Not sure if an external oil leak on the oil cooler is common?
Depending upon your year, here are some common problems:
Oil Cooler Plugging up and usually taking out the EGR Cooler with it
Snap to Connect fitting on your HPOP *updated part available
kit also comes with all gaskets and new screen for your IPR
D-Ring failure on the crankcase to vent tube and dummy plugs *updated parts available
Turbo Drain and Feed tubes have been updated. I only replaced my Drain tube because the feed tube was retartedly priced at over $100 even @ 10% over dealer cost.
Screen under oil cooler for HPOP has been changed to metal rather than cloth. Oil Cooler Kit should come with this part.
I replaced all gaskets and o-rings on the top end while I was in there including headgaskets. Cheap insurance (accually not so cheap)
Replaced stock TTY Head bolts with ARP's Head Stud's
You might think about replacing the thermostat and housing while in there.
Perhaps a turbo cleaning while its out. I found a brass brush attachment for my drill alot better than the 3m kit recommended, but my turbo wasnt horrible.
Old 04-16-2011, 02:39 PM
350crew4x4's Avatar
350crew4x4
I should have given some back ground information. I drove to work (40 miles) drove ok spitted alitle but cleaed up so I didn't think anything of it. Got in to satrt it up and leave andthe truck wouldn't start. Had it towed to a shop , they did there thing and told me it was the ICP that there wasent enough oil pressure to start the motor. Had them replace it, went to pick the truck up and they couldn't start it and now there is a MAJOR oil leak that they told me was the oil cooler, it's very ahrd to start and won't stay running fr more than 5 seconds. I wonder if this isn't the result of them pressurizing the system ? I decided to fix the truck myself.
I'm still reading thru the tech folder, good stuff.
Old 04-16-2011, 03:28 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
can you see oil in the coolant reservoir
or is it runing out around the bottom of oil filter housing
Old 11-12-2017, 01:15 PM
dwb133's Avatar
dwb133
dwb133 is offline
I think my egr cooler is leaking. Not much, but leaking. Is it ok to drive 35 miles to my technicians shop?
Old 11-12-2017, 03:53 PM
Bruce Thompson's Avatar
Bruce Thompson
Bruce Thompson is offline
Yes you can drive to your repair shop. Just make sure you have topped off the coolant.
66v8baby
04-21-2017 06:20 PM
_Trekker
02-18-2017 11:22 PM
LRSTony
09-10-2016 09:37 PM
cx300
All Other Items for Sale
07-27-2016 08:41 PM
RocketDogs
03-14-2016 09:26 AM
Quick Reply: 04 6.0 oil & egr location
