Oil Sender question
Old Feb 18, 2017 | 11:06 PM
_Trekker's Avatar
_Trekker
Oil Sender question
I just bought an 88 f250 with a 460 in it. Test drive went well, needs some work but it seemed fine. Driving it later I realized that the oil gauge moves around a lot considering it's supposed to be an on/off switch. It will dip and show no oil pressure although there is no valve chatter or noise, so I'm certain that it still has pressure. When looking up the oil sender location to inspect wiring, I saw two separate locations, center on the rear of the engine by the intake manifold and by the oil filter, which is it?
Old Feb 18, 2017 | 11:22 PM
White 97 xlt's Avatar
White 97 xlt
On the 460 it's in the back of the engine, behind the throttle body.. The small block V8's have it down by the filter...
MustangMatt96GT
Dec 7, 2008 03:22 PM
79 Camper Special
Nov 8, 2007 11:54 AM
lilmick21602
1978 - 1996 Big Bronco
Apr 24, 2007 12:22 PM
66MercMan
Jan 22, 2004 02:17 PM
mikem78
Dec 12, 2003 02:36 PM
