Exhaust System
Old 04-10-2011, 11:31 AM
Wicked Endings's Avatar
Wicked Endings
Wicked Endings is offline
Exhaust System
Hey guys! I've got a 1985 Ford F-150 with a 4.9L 300 Six.
I am looking for an entire exhaust system, I just don't know where to get it for my year/make/model truck...
If you know where I could buy it, let me know!
Old 04-10-2011, 11:41 AM
billt28's Avatar
billt28
billt28 is offline
Google it. I know JEGS, & NPD sell them.
Old 04-10-2011, 11:45 AM
Wicked Endings
I googled a lot of them, but I trust the guys on FTE, so I always ask for the advice of you guys.
I'll look at NPD.
EDIT: NPD doesn't even sell my year exhaust system... :P
Old 04-10-2011, 05:47 PM
cadunkle's Avatar
cadunkle
cadunkle is offline
Doubt anyone makes a bolt in deal. Probably run you $500 or less at a local exhaust shop. I'd recommend since you'll be doing the exhaust to snag a dual outlet exhaust manifold off a newer fuel injected big six before doing the exhaust. It should give a slight performance improvement.
Old 04-10-2011, 05:57 PM
billt28's Avatar
billt28
billt28 is offline
They make a bolt in system for the 4.9, I've seen them, just can't remember where. I'll have to check after while and see where.
Old 04-10-2011, 09:09 PM
newrider3's Avatar
newrider3
newrider3 is offline
Switch to EFI split manifolds, the increase in power is quite noticeable.
You can then use a Walker 45166 y-pipe. They also make a direct fit cat, muffler, and tailpipe, I'm not sure about the part numbers for those.
A lot of people also choose to go with a turbo-style muffler after the y-pipe, and dump just in front of the rear tire. Usually sounds pretty good.
Here's some good pics:
1981 Ford Bronco Exhaust Upgrade pictures, videos, and sounds | SuperMotors.net
Old 04-11-2011, 04:31 PM
Dynomax Exhaust's Avatar
Dynomax Exhaust
Dynomax Exhaust is offline
PREMIUM SPONSOR
Red face
Not too sure on how much difference between a 85 to a 87 ( I know there is a gen break, but not too sure how much difference under the chassis) but we do have two systems that MIGHT work for you. This is for 87-96's though.
Dynomax PN 17447 (2.25 pipe diameter)
Dynomax PN 17312 (2.5 pipe diameter)
__________________
Follow us on Facebook!
https://www.facebook.com/dynomaxexhaust
http://www.dynomax.com
Old 04-11-2011, 04:42 PM
cadunkle's Avatar
cadunkle
cadunkle is offline
87-96 would be fuel injected. Aside from that the frames are the same. So basically you'd need a split outlet manifold from a fuel injected truck then you should be able to use the Dynomax bolt on exhaust.
Old 04-11-2011, 04:47 PM
Dynomax Exhaust
PREMIUM SPONSOR
Talking
One of the very first posts I made on this board was how much knowledge there was here, and you provided a little more for me!
__________________
Old 04-11-2011, 04:48 PM
newrider3's Avatar
newrider3
I'm pretty sure that the Walker part # I posted above is what you would get from Dynomax-they are one and the same.
Old 04-11-2011, 05:24 PM
Dynomax Exhaust
PREMIUM SPONSOR
Walker and Dynomax have the same parent company. But a lot of the mufflers have different designs internally.
PS your post was another "learning post" for me as well.
Thanks for sharing.
__________________
Old 04-12-2011, 03:50 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The walker Y pipe is large internally but often the hole in the one pipe where they are welded together is a restriction.
You can take a 1 7/8" hole saw with an extension and open it up.
(these pic's are from Josiah's 300 build thread)
Stock EFI split manifold, individual pipes:
EFI manifolds, Walker Y pipe:
This is a view inside the Y-pipe with the hole cut out where the rear pipe is fishmouthed and welded onto the front one:
Old 04-12-2011, 10:55 AM
6CylBill's Avatar
6CylBill
6CylBill is offline
Found a guy on YouTube (sounded like an old man) put true duals on his 300 with Flowmaster Super 44's, no cats. It honestly sounded like a V8. Very very mean. I was very much impressed.
Old 04-12-2011, 11:24 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
What is "old"?
Old 04-12-2011, 12:20 PM
6CylBill's Avatar
6CylBill
6CylBill is offline
Uh.. that wasn't you, was it?
If so, oopsies!
Is your truck blue?
Quick Reply: Exhaust System
