highboy gear ratios?
1963/80 F100/350: The Warranty Plate is located on the left door face below the latch.
Post the AXLE code from it.
Dana 44/60: The Ford front/rear axle ID tags are located under one of the bolts that retain the inspection cover to the housing, but...today, many are missing. The code will be similar to this: D6TA-AA.
The Dana 60 ID tag is bolted to the housing adjacent to the inspection cover. The tags ID number will have either 7 or 8 digits, similar to this: 603010-1 or this: 603010-11.
Post what you find, I can decode all of it.
704 denside man: The glued on white Safety Standards Certification Label is located on the B pillar. It does not have the AXLE code on it, only the trucks production date, front/rear GVW's and sometimes the tire sizes.
1973/79 F250 4WD: 3.54-1 (Dana 44), 4.10-1 & 4.56-1 were the available ratios / 3.50-1 = F100/150 & Bronco only / No 3.73's with 4WD, 2WD only / No 3.55's were available in F250's until the 1980's.
Dashmercury
09-20-2016 10:38 PM
Brohamady
04-06-2016 12:26 PM
jamusfam
04-24-2014 06:20 PM
Dave2488
20
05-29-2012 06:28 AM
eXtremeYJ
17
10-28-2009 03:00 PM
