which way to adjust rear drum brakes?
I put new hardware kits on my rear brakes this weekend. My star wheels were two different colors, one gold one silver. The plates that keep the star wheels from turning were labeled L and R. I'm assuming L = left and R =right. However, when installed the locking plates don't stop the star wheels from being adjusted either way. To me it looks like the L&R plates should be swapped and they would work correct. Left side is referenced to what? Is there any significance to the star wheels being gold and silver? Need help.....
On the adjuster plate the flats face the front, the "high hole" to the rear to connect to the parking brake cable. The adjuster wheel sits under and is engaged by the flats.
The adjusting wheels are usually stamped L/R as well under the end cap
When adjusting with the drum on and using an adjusting tool...the tool is engaged to the star wheel through the slot in the backing plate, then the tool is levered downward toward you (thereby rotating the star wheel toward you as well) This is true on either side of the vehicle when facing the drum.
https://www.ford-trucks.com/forums/7...e-diagram.html
bert cook
36
02-08-2016 06:11 AM
animaldawg
10-20-2014 09:45 PM
mike bell
12-18-2011 12:16 PM
