1950 F5 rear brake dragging
Old 08-21-2014, 09:16 AM
animaldawg's Avatar
animaldawg
animaldawg is offline
I have a 1950 F5 parcel delivery and the passenger rear brake is dragging. the question I have is what way do you turn the upper cam bolts to loosen the brake shoes. I have found instructions on line on how to adjust the position of the brake shoes but does not say which way loosens or tightens the brake shoes. when the truck tires are off the ground I can turn the driver side wheels by hand but not the passenger wheels
Thanks Mike
Old 08-21-2014, 10:10 AM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
The cams should be turned top toward the top of the axle to release the adjustment. There should be a slot near the outside edge of the drum where you can see the shoe and measure clearance. Don't forget the bottom anchor pins are adjustable, also. Use the visual slot
Old 08-21-2014, 01:17 PM
animaldawg's Avatar
animaldawg
brakes
Thanks for the help: raytasch
Old 08-21-2014, 02:45 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Lower Pic: JH = F3 Parcel Delivery / T = F5 / TH = F6 / W = F5 COE / WH = F6 COE
Old 10-20-2014, 09:39 PM
Tripleaaasoda's Avatar
Tripleaaasoda
Tripleaaasoda is offline
I wanted to see if anyone had a good place to get brake shoes. Part numbers 2022 and 2021
or is it 2019 and 2018
Old 10-20-2014, 09:45 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
Those are just the 'generic' numbers, it depends on which year and model truck you are looking for. If you are talking about 48-52 F4-F6, the shoes are not available, but you can find shops that can reline them.
Edit:: I see that you have a 51 F6 COE the shoes would be Rear 91T2018-C/91T2019-C Front 92Y 2018-c / 92y 2019-c, but as I said above, you will find none available. I located a local clutch shop that was able to make and install linings at a reasonable price.
mhbell
1997 - 2003 F150
22
11-10-2017 06:30 PM
animaldawg
08-21-2014 12:53 PM
Eddillard79
01-03-2014 08:38 AM
Nightintruder
1999 to 2016 Super Duty
11-29-2010 07:27 PM
m@m
2004 - 2008 F150
05-26-2007 11:38 AM
Quick Reply: 1950 F5 rear brake dragging
