I finally got the cab on and truck started! got it started and idles good. but when it got to temp there was an oil leak on the back side of the motor starting from the top and runnin down the heads. but i think its the hpop area because when i go to start the motor you can crank for about 10 secs before the oil psi gauge moves then it slowly moves up and then the truck starts. if the hpop cover gasket is leaking would that cause the low pressure?
looks like thats where it is coming from!!! either there or hpop gasket. going to have my machanic do it being that im headed back to school and dont have time now and he is doing the brakes anyways. im going to also have him check over all my work to make sure everything is sound!
