Differential Fluid Change
http://www.motorcraftservice.com/pub.../05f23og3e.pdf
Front axle Motorcraft SAE
80W-90
Premium Rear
Axle Lubricant
6.3 pints (3.0L)
F-250/350
(Dana 60 axle)
Rear axle
Motorcraft SAE
75W-140
Synthetic Rear
Axle Lubricant
6.9 pints (3.3L)
F-250 /350
(10.50 inch
axle)
1Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent
meeting Ford Specification EST-M2C118–A for complete refill of limited
slip axles. Ford design rear axles contain a synthetic lubricant that does
not require changing unless the axle has been submerged in water. Dana
rear axles also contain a synthetic lubricant but do require a change.
Refer to your Scheduled Maintenance Guide for change intervals on
Dana rear axles
80W-90
Premium Rear
Axle Lubricant
6.3 pints (3.0L)
F-250/350
(Dana 60 axle)
Rear axle
Motorcraft SAE
75W-140
Synthetic Rear
Axle Lubricant
6.9 pints (3.3L)
F-250 /350
(10.50 inch
axle)
Dana rear axles
Rocky, the link didn't work.
Here are some links for the OP also, just some helpful pictures, Rocky's info is great.
Welcome to guzzle's Rear Differential Maintenance Web Page
Welcome to guzzle's Front Differential Maintenance Web Page
https://www.flmowner.com/servlet/Con...e&ord=83940643
Would you know if there is a link for the Dana 80. I believe that is the axle I have on my 03 rear axle on my Dually??
PS: Thanks for the links
Texas Bob
1999 to 2016 Super Duty
10-19-2019 12:12 AM
CrispyWafer
10-10-2016 07:28 PM
hermancm
05-20-2012 03:15 PM
bustedflush
15
09-07-2007 03:02 AM
