DP-Tuner Chip
Great Thanks Bryan... Just spoke with Clay at Riffraff and he basically said the same thing. He mentioned the F8 is a good tuner if you want other peoples Mods as well as DP's on the same chip. I think I'm going with the F5.
Sidenote... Anyone running the ISSPRO EV2 Gauges? What are the required temp ranges needed for capturing the relevent data (Pyro, Trans & Boost)
Thanks
Thanks
You want the lowest of all of the ranges for the gauges.
i just never saw the need for more than 5 positions, you really going to use incrimental power at 20hp?? nah, your going to stay at stock, maybe 40tow which is next to nothing. 80e is a nice town booter. 120 is all youll see for a gain which isnt that much more than 80 with stock injectors. no start is stock on all chips and maybe a lope tune to show your buddies which i use maybe...1% of the time if that.i use 3 of my tunes. stock, 80 and my hot tune only because its more driveable. pretty peppy on the throttle which is what i like.
I got this reply from DP's Techie James Breeden (contact info below)-
The Decel tune works like a exhaust brake but you have a 96 model and do not have a Exhuast Back Pressure Valve in your truck so this would not work for you....sorry.
From the website:
Decel tune- this is used instead of an expensive exhaust brake. It performs the same function by using the EBPV to slow the trucks down. Some transmission strategies are used for auto transmissions also.
Just switch to the Decel tune, let off throttle and it closes EBPV, locks tq converter and increases line pressures. When you get to the bottom of the hill switch back to the tow tune and away you go. Works pretty good for the money and alot of folks like it.
Thank You
James Breeden
Technical Support
DP-Tuner
tech@dp-tuner.com
james@dp-tuner.com
(423) 709-8640 Office
Question...I thought our trucks did have an EBPV???
From the website:
Thank You
James Breeden
Technical Support
DP-Tuner
tech@dp-tuner.com
james@dp-tuner.com
