Blackstone engine oil analysis
Its possible the long block could have sat a bit before you got it and developed some corrosion which your now seeing on the UOA since the engine is in service. Maybe try a slightly higher viscosity oil like a 5w-30 and see if anything changes, should give you better hot protection. I can't really think of anything you can do about about it without tearing the engine down and inspecting it. If it is running good and sounds good I would get another UOA in 3k miles and see how it looks. I take it you are using a Motorcraft 820S filter?
A UOA or two in this thread, including one I posted. The UOA I posted was with 34k miles on the engine at that time.
https://www.ford-trucks.com/forums/7...is-report.html
Interesting.
Since the bearings are aluminum-silicon, and your silicon reading is three times the average, and aluminum is high too, I would start wondering...
Definitely do another analysis, I'd certainly want to keep an eye on that.
This is interesting: Sources of Elements found in Oil Analysis
Silicon can be in synthetic oils.
I wonder, if you asked Mobil about the analysis, if you'd get an answer?
Interesting.
Check BITOG www.bobistheoilguy.com and you will find that Mobil1 UOAs consistantly show high iron levels. No one has come up with a good explanation for this. Tear downs of engines run on Mobil1 show them to be very clean and weel within tolerances though. One thing I've noticed having used Mobil1 in several different Ford modular motors is that there is some oil lost. Switched to Penzoil Platinum and no oil usage at all.
sunogbahay
29
09-09-2011 12:45 PM
