I pulled my front clip to swap 460, and I was gonna order the full body mount/hardware set from jbg but they are out of stock. I need to bolt the core support back to the frame for now. Both my bolts were rusted and one broke off inside the lower sleeve and the other I had to cut off and both of them are too destroyed to reuse. Big bolts, big washers, whats left of the rubber mounts between the core support and the frame?
I used a large washer and tube to re-make the lower, metal part of mine. The rubbers and uppers were salvagable but I just ordered a full poly set. If you want parts I can sell some stock stuff.
yeah if I had a decent yard anywhere near me it would speed up projects a lot! I think a found a place selling the poly bushings with sleeves and washers. Gonna order them and see.
yeah i left a truck sit with no core support and fenders still attached for like 6 months, no problems. As for the bed, I don't think the bed had absorbers? Neither of the 2 beds I've pulled had any rubber between the bed and the frame, just bolts.
There are rubber/cloth type flat square pads between the bed mounts and the frame on mine. The pads look almost like side wall tire material. Kind of. They are completely worn out. I checked LMC (heck of a lot of pages, lots of stuff) BUT could not find bed-to-frame absorbers. All the trucks I've seen at the wreckers where also pretty well worn out. If I've going to go though the trouble of replacing them,,, kind of like to have new ones.
'ChaseTruck', did you actually see the 'bed to frame' absorbers at LMC? Maybe you could tell me what page its on. OR, another place I could get them.
Any one else know
This is for may 65' F-100
Thanks, Fritz
